enable iparp gratuitous protect
enable iparp gratuitous protect [ {vlan} vlan_name | vlan vlan_list]
Description
Enables gratuitous ARP protection on the specified VLAN.
Syntax Description
vlan_name Specifies the VLAN.
vlan_list Specifies a VLAN list of IDs.
Default
By default, gratuitous ARP is disabled.
Usage Guidelines
Beginning with ExtremeXOS 11.6, this command replaces this command for configuring gratuitous ARP.
Hosts can launch man-in-the-middle attacks by sending out gratuitous ARP requests for the router's IP address. This results in hosts sending their router traffic to the attacker, and the attacker forwarding that data to the router. This allows passwords, keys, and other information to be intercepted.
To protect against this type of attack, the router will send out its own gratuitous ARP request to override the attacker whenever a gratuitous ARP broadcast with the router's IP address as the source is received on the network.
The following example enables gratuitous ARP protection for VLAN corp:
enable iparp gratuitous protect vlan corp
The vlan_list option was added in ExtremeXOS 16.1.
Platform Availability
